LuxCore  2.0
 All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Macros
luxcore::RenderConfig Class Referenceabstract
RenderConfig stores all the configuration settings used to render a scene. More...
#include <luxcore.h>
Public Member Functions
virtual ~RenderConfig ()
virtual const luxrays::Properties & GetProperties () const =0
 Returns a reference to the Properties used to create the RenderConfig. More...
virtual const luxrays::Property GetProperty (const std::string &name) const =0
 Returns the Property with the given name or the default value if it has not been defined. More...
virtual const luxrays::Properties & ToProperties () const =0
 Returns a reference to all Properties (including default values) defining the RenderConfig. More...
virtual Scene & GetScene () const =0
 Returns a reference to the Scene used in the RenderConfig. More...
virtual void Parse (const luxrays::Properties &props)=0
 Sets configuration Properties with new values. This method can be used only when the RenderConfig is not in use by a RenderSession. More...
virtual void Delete (const std::string &prefix)=0
 Deletes any configuration Property starting with the given prefix. This method can be used only when the RenderConfig is not in use by a RenderSession. More...
virtual bool GetFilmSize (unsigned int *filmFullWidth, unsigned int *filmFullHeight, unsigned int *filmSubRegion) const =0
 Return the configured Film width, height, sub-region width, height, and if sub-region is enabled. More...
virtual void DeleteSceneOnExit ()=0
 Delete the scene passed to the constructor when the class destructor is invoked. More...
virtual void Save (const std::string &fileName)=0
 Save all the scene related information (the LuxCore RenderConfig, and Scene) in a file. More...
virtual void Export (const std::string &dirName)=0
 Save all the scene related information (the LuxCore RenderConfig, and Scene) in a directory using text format for the SDL. This performs the same work of FILESAVER render engine. More...
Static Public Member Functions
static RenderConfig * Create (const luxrays::Properties &props, Scene *scene=NULL)
 Create a new RenderConfig using the provided Properties and (optional) Scene. More...
static RenderConfig * Create (const std::string &fileName)
 Create a new RenderConfig using the provided binary file. More...
static RenderConfig * Create (const std::string &fileName, RenderState **startState, Film **startFilm)
 Create a new RenderConfig using the provided resume binary file. More...
static const luxrays::Properties & GetDefaultProperties ()
 Returns a Properties container with all default values. More...
Detailed Description
Definition at line 907 of file luxcore.h.
Constructor & Destructor Documentation
virtual luxcore::RenderConfig::~RenderConfig ( )
virtual
Member Function Documentation
static RenderConfig* luxcore::RenderConfig::Create ( const luxrays::Properties &  props,
Scene *  scene = NULL
static
Parameters
propsare the Properties used to build the new RenderConfig.
sceneis the Scene used to build the new RenderConfig. If specified, the Scene will not be deleted by the destructor. If NULL, the Scene will be read from the file specified in the "scene.file" Property and deleted by the destructor.
static RenderConfig* luxcore::RenderConfig::Create ( const std::string &  fileName)
static
Parameters
fileNameis the binary file used to build the new RenderConfig. The extension for the binary format must be ".bcf".
static RenderConfig* luxcore::RenderConfig::Create ( const std::string &  fileName,
RenderState **  startState,
Film **  startFilm
static
Parameters
fileNameis the binary file used to build the new RenderConfig. The extension for the binary format must be ".rsm".
startStatethe pointer to the render state will be returned here.
startFilmthe pointer to the film will be returned here.
virtual void luxcore::RenderConfig::Delete ( const std::string &  prefix)
pure virtual
Parameters
prefixis the prefix of the Properties to delete.
virtual void luxcore::RenderConfig::DeleteSceneOnExit ( )
pure virtual
virtual void luxcore::RenderConfig::Export ( const std::string &  dirName)
pure virtual
static const luxrays::Properties& luxcore::RenderConfig::GetDefaultProperties ( )
static
Returns
the default Properties.
virtual bool luxcore::RenderConfig::GetFilmSize ( unsigned int *  filmFullWidth,
unsigned int *  filmFullHeight,
unsigned int *  filmSubRegion
) const
pure virtual
Parameters
filmFullWidthis where the configured Film width is returned if the pointer is not NULL.
filmFullHeightis where the configured Film height is returned if the pointer is not NULL.
filmSubRegionis an array of 4 values with the horizontal (followed by the vertical) begin and end of the Film region to render (in pixels).
Returns
true if there is a sub-region to render, false otherwise.
virtual const luxrays::Properties& luxcore::RenderConfig::GetProperties ( ) const
pure virtual
Returns
the RenderConfig properties.
virtual const luxrays::Property luxcore::RenderConfig::GetProperty ( const std::string &  name) const
pure virtual
Returns
the Property with the given name.
virtual Scene& luxcore::RenderConfig::GetScene ( ) const
pure virtual
Returns
the reference to the RenderConfig Scene.
virtual void luxcore::RenderConfig::Parse ( const luxrays::Properties &  props)
pure virtual
Parameters
propsare the Properties to set.
virtual void luxcore::RenderConfig::Save ( const std::string &  fileName)
pure virtual
virtual const luxrays::Properties& luxcore::RenderConfig::ToProperties ( ) const
pure virtual
Returns
The documentation for this class was generated from the following file:
