LuxCore  2.0
 All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Macros
luxrays::Properties Class Reference
A container for multiple Property. More...
#include <properties.h>
Collaboration diagram for luxrays::Properties:
Public Member Functions
 Properties ()
 Properties (const std::string &fileName)
 Sets the list of Property from a text file . More...
 ~Properties ()
unsigned int GetSize () const
 Returns the number of Property in this container. More...
Properties & Set (const Property &prop)
 Sets a single Property. More...
Properties & operator<< (const Property &prop)
Properties & Set (const Properties &prop)
 Sets the list of Property. More...
Properties & operator<< (const Properties &props)
Properties & Set (const Properties &props, const std::string &prefix)
 Sets the list of Property while adding a prefix to all names. More...
Properties & SetFromStream (std::istream &stream)
 Sets the list of Property coming from a stream. More...
Properties & SetFromFile (const std::string &fileName)
 Sets the list of Property coming from a file. More...
Properties & SetFromString (const std::string &propDefinitions)
 Sets the list of Property coming from a std::string. More...
Properties & Clear ()
 Removes all Property from the container. More...
const std::vector< std::string > & GetAllNames () const
 Returns all Property names defined. More...
std::vector< std::string > GetAllNames (const std::string &prefix) const
 Returns all Property names that start with a specific prefix. More...
std::vector< std::string > GetAllNamesRE (const std::string &regularExpression) const
 Returns all Property unique names that match the passed regular expression. More...
std::vector< std::string > GetAllUniqueSubNames (const std::string &prefix) const
 Returns all Property unique names that start with a specific prefix. More...
bool HaveNames (const std::string &prefix) const
 Returns if there are at least a Property starting for specific prefix. More...
bool HaveNamesRE (const std::string &regularExpression) const
 Returns all a copy of all Property with a name starting with a specific prefix. More...
Properties GetAllProperties (const std::string &prefix) const
 Returns a copy of all Property with a name matching the passed regular expression. More...
const Property & Get (const std::string &propName) const
 Returns a property. More...
const Property & Get (const Property &defaultProp) const
 Returns a Property with the same name of the passed Property if it has been defined or the passed Property itself (i.e. the default values). More...
bool IsDefined (const std::string &propName) const
 Returns if a Property with the given name has been defined. More...
void Delete (const std::string &propName)
 Deletes a Property with the given name. More...
void DeleteAll (const std::vector< std::string > &propNames)
 Deletes all listed Property. More...
std::string ToString () const
 Converts all Properties in a string. More...
Private Attributes
std::vector< std::string > names
std::map< std::string, Property > props
Detailed Description
Properties is a container for instances of Property class. It keeps also track of the insertion order.
Definition at line 502 of file properties.h.
Constructor & Destructor Documentation
luxrays::Properties::Properties ( )
inline
Definition at line 504 of file properties.h.
luxrays::Properties::Properties ( const std::string &  fileName)
Parameters
fileNameis the name of the file to read.
luxrays::Properties::~Properties ( )
inline
Definition at line 511 of file properties.h.
Member Function Documentation
Properties& luxrays::Properties::Clear ( )
Returns
a reference to the modified properties.
void luxrays::Properties::Delete ( const std::string &  propName)
Parameters
propNameis the name of the Property to delete.
void luxrays::Properties::DeleteAll ( const std::vector< std::string > &  propNames)
Parameters
propNamesis the list of the Property to delete.
const Property& luxrays::Properties::Get ( const std::string &  propName) const
Returns a property.
Parameters
propNameis the name of the Property to return.
Returns
a Property.
Exceptions
std::runtime_errorif the Property doesn't exist.
const Property& luxrays::Properties::Get ( const Property &  defaultProp) const
Parameters
defaultProphas the Property to look for and the default values in case it has not been defined.
Returns
a Property.
const std::vector<std::string>& luxrays::Properties::GetAllNames ( ) const
Returns
a reference to all Property names defined.
std::vector<std::string> luxrays::Properties::GetAllNames ( const std::string &  prefix) const
This method is used to iterate over all properties.
Parameters
prefixof the Property names to return.
Returns
a vector of Property names.
std::vector<std::string> luxrays::Properties::GetAllNamesRE ( const std::string &  regularExpression) const
Parameters
regularExpressionto use for the pattern matching.
Returns
Properties luxrays::Properties::GetAllProperties ( const std::string &  prefix) const
Parameters
Returns
a copy of all Property matching the prefix.
std::vector<std::string> luxrays::Properties::GetAllUniqueSubNames ( const std::string &  prefix) const
For instance, given the the following names:
  • test.prop1.subprop1
  • test.prop1.subprop2
  • test.prop2.subprop1
GetAllUniqueSubNames("test") will return:
  • test.prop1
  • test.prop2
Parameters
Returns
unsigned int luxrays::Properties::GetSize ( ) const
Returns
the number of Property.
bool luxrays::Properties::HaveNames ( const std::string &  prefix) const
Parameters
prefixof the Property to look for.
Returns
true if there is at least on Property starting for the prefix.
bool luxrays::Properties::HaveNamesRE ( const std::string &  regularExpression) const
Parameters
prefixof the Property names to use.
Returns
bool luxrays::Properties::IsDefined ( const std::string &  propName) const
Parameters
propNameis the name of the Property to check.
Returns
if defined or not.
Properties& luxrays::Properties::operator<< ( const Property &  prop)
Parameters
propis the Property to set.
Returns
Properties& luxrays::Properties::operator<< ( const Properties &  props)
Parameters
propsis the list of Property to set.
Returns
Properties& luxrays::Properties::Set ( const Property &  prop)
Parameters
Returns
Properties& luxrays::Properties::Set ( const Properties &  prop)
Parameters
propis the list of Property to set.
Returns
Properties& luxrays::Properties::Set ( const Properties &  props,
Parameters
Returns
Properties& luxrays::Properties::SetFromFile ( const std::string &  fileName)
Parameters
Returns
Properties& luxrays::Properties::SetFromStream ( std::istream &  stream)
Parameters
streamis the input stream to read.
Returns
Properties& luxrays::Properties::SetFromString ( const std::string &  propDefinitions)
Parameters
propDefinitionsis the list of Property to add in text format.
Returns
std::string luxrays::Properties::ToString ( ) const
Returns
a string with the definition of all properties.
Referenced by luxrays::operator<<().
Member Data Documentation
std::vector<std::string> luxrays::Properties::names
private
Definition at line 713 of file properties.h.
std::map<std::string, Property> luxrays::Properties::props
private
Definition at line 714 of file properties.h.
The documentation for this class was generated from the following file:
