LuxCore
2.0
Value that can be stored in a Property. More...
#include <properties.h>
Public Types | |
| enum | DataType { NONE_VAL, BOOL_VAL, INT_VAL, UINT_VAL, FLOAT_VAL, DOUBLE_VAL, ULONGLONG_VAL, STRING_VAL, BLOB_VAL } |
Public Member Functions | |
| PropertyValue () | |
| PropertyValue (const PropertyValue &propVal) | |
| PropertyValue (const bool val) | |
| PropertyValue (const int val) | |
| PropertyValue (const unsigned int val) | |
| PropertyValue (const float val) | |
| PropertyValue (const double val) | |
| PropertyValue (const unsigned long long val) | |
| PropertyValue (const std::string &val) | |
| PropertyValue (const Blob &val) | |
| ~PropertyValue () | |
| template<class T > | |
| T | Get () const |
| DataType | GetValueType () const |
| PropertyValue & | operator= (const PropertyValue &propVal) |
| template<> | |
| CPP_API bool | Get () const |
| template<> | |
| CPP_API int | Get () const |
| template<> | |
| CPP_API unsigned int | Get () const |
| template<> | |
| CPP_API float | Get () const |
| template<> | |
| CPP_API double | Get () const |
| template<> | |
| CPP_API unsigned long long | Get () const |
| template<> | |
| CPP_API const Blob & | Get () const |
Static Private Member Functions | |
| static void | Copy (const PropertyValue &prop0Val, PropertyValue &prop1Val) |
Private Attributes | |
| DataType | dataType |
| union { | |
| bool boolVal | |
| int intVal | |
| unsigned int uintVal | |
| float floatVal | |
| double doubleVal | |
| unsigned long long ulonglongVal | |
| std::string * stringVal | |
| Blob * blobVal | |
| } | data |
The current list of allowed data types is:
Definition at line 82 of file properties.h.
| Enumerator | |
| NONE_VAL | |
| BOOL_VAL | |
| INT_VAL | |
| UINT_VAL | |
| FLOAT_VAL | |
| DOUBLE_VAL | |
| ULONGLONG_VAL | |
| STRING_VAL | |
| BLOB_VAL | |
Definition at line 84 of file properties.h.
| luxrays::PropertyValue::PropertyValue | ( | ) |
| luxrays::PropertyValue::PropertyValue | ( | const PropertyValue & | propVal | ) |
| luxrays::PropertyValue::PropertyValue | ( | const bool | val | ) |
| luxrays::PropertyValue::PropertyValue | ( | const int | val | ) |
| luxrays::PropertyValue::PropertyValue | ( | const unsigned int | val | ) |
| luxrays::PropertyValue::PropertyValue | ( | const float | val | ) |
| luxrays::PropertyValue::PropertyValue | ( | const double | val | ) |
| luxrays::PropertyValue::PropertyValue | ( | const unsigned long long | val | ) |
| luxrays::PropertyValue::PropertyValue | ( | const std::string & | val | ) |
| luxrays::PropertyValue::PropertyValue | ( | const Blob & | val | ) |
| luxrays::PropertyValue::~PropertyValue | ( | ) |
staticprivate |
| T luxrays::PropertyValue::Get | ( | ) | const |
| CPP_API bool luxrays::PropertyValue::Get | ( | ) | const |
| CPP_API int luxrays::PropertyValue::Get | ( | ) | const |
| CPP_API unsigned int luxrays::PropertyValue::Get | ( | ) | const |
| CPP_API float luxrays::PropertyValue::Get | ( | ) | const |
| CPP_API double luxrays::PropertyValue::Get | ( | ) | const |
| CPP_API unsigned long long luxrays::PropertyValue::Get | ( | ) | const |
| CPP_API const Blob& luxrays::PropertyValue::Get | ( | ) | const |
| DataType luxrays::PropertyValue::GetValueType | ( | ) | const |
| PropertyValue& luxrays::PropertyValue::operator= | ( | const PropertyValue & | propVal | ) |
| Blob* luxrays::PropertyValue::blobVal |
Definition at line 127 of file properties.h.
| bool luxrays::PropertyValue::boolVal |
Definition at line 120 of file properties.h.
| union { ... } luxrays::PropertyValue::data |
private |
Definition at line 117 of file properties.h.
| double luxrays::PropertyValue::doubleVal |
Definition at line 124 of file properties.h.
| float luxrays::PropertyValue::floatVal |
Definition at line 123 of file properties.h.
| int luxrays::PropertyValue::intVal |
Definition at line 121 of file properties.h.
| std::string* luxrays::PropertyValue::stringVal |
Definition at line 126 of file properties.h.
| unsigned int luxrays::PropertyValue::uintVal |
Definition at line 122 of file properties.h.
| unsigned long long luxrays::PropertyValue::ulonglongVal |
Definition at line 125 of file properties.h.
