Camera stores camera definitions.
More...
#include <luxcore.h>
Definition at line 446 of file luxcore.h.
Types of cameras.
| Enumerator |
| PERSPECTIVE |
| ORTHOGRAPHIC |
| STEREO |
| ENVIRONMENT |
Definition at line 451 of file luxcore.h.
| virtual luxcore::Camera::~Camera |
virtual |
| virtual const CameraType luxcore::Camera::GetType |
const |
pure virtual |
Returns the camera type.
- Returns
- a camera type.
| virtual void luxcore::Camera::Rotate |
const float |
angle, |
const float |
x, |
const float |
y, |
const float |
z |
| const |
pure virtual |
Rotates by angle around the axis. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| angle | is the rotation angle. |
| axis | is the rotation axis. |
| virtual void luxcore::Camera::RotateDown |
const float |
angle | ) |
const |
pure virtual |
Rotates down by angle. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| virtual void luxcore::Camera::RotateLeft |
const float |
angle | ) |
const |
pure virtual |
Rotates left by angle. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| virtual void luxcore::Camera::RotateRight |
const float |
angle | ) |
const |
pure virtual |
Rotates right by angle. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| virtual void luxcore::Camera::RotateUp |
const float |
angle | ) |
const |
pure virtual |
Rotates up by angle. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| virtual void luxcore::Camera::Translate |
const float |
x, |
const float |
y, |
const float |
z |
| const |
pure virtual |
Translates by vector t. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| t | is the translation vector. |
| virtual void luxcore::Camera::TranslateBackward |
const float |
t | ) |
const |
pure virtual |
Translates backward by t. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| t | is the translation distance. |
| virtual void luxcore::Camera::TranslateForward |
const float |
t | ) |
const |
pure virtual |
Translates forward by t. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| virtual void luxcore::Camera::TranslateLeft |
const float |
t | ) |
const |
pure virtual |
Translates left by t. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
| virtual void luxcore::Camera::TranslateRight |
const float |
t | ) |
const |
pure virtual |
Translates right by t. This method can be used only when the Scene is not in use by a RenderSession.
- Parameters
The documentation for this class was generated from the following file:
