LuxCore  2.0
 All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Macros
luxrays::PropertyValue Class Reference
Value that can be stored in a Property. More...
#include <properties.h>
Collaboration diagram for luxrays::PropertyValue:
Public Types
enum  DataType {
  NONE_VAL, BOOL_VAL, INT_VAL, UINT_VAL,
  FLOAT_VAL, DOUBLE_VAL, ULONGLONG_VAL, STRING_VAL,
  BLOB_VAL
Public Member Functions
 PropertyValue ()
 PropertyValue (const PropertyValue &propVal)
 PropertyValue (const bool val)
 PropertyValue (const int val)
 PropertyValue (const unsigned int val)
 PropertyValue (const float val)
 PropertyValue (const double val)
 PropertyValue (const unsigned long long val)
 PropertyValue (const std::string &val)
 PropertyValue (const Blob &val)
 ~PropertyValue ()
template<class T >
T Get () const
DataType GetValueType () const
PropertyValue & operator= (const PropertyValue &propVal)
template<>
CPP_API bool Get () const
template<>
CPP_API int Get () const
template<>
CPP_API unsigned int Get () const
template<>
CPP_API float Get () const
template<>
CPP_API double Get () const
template<>
CPP_API unsigned long long Get () const
template<>
CPP_API const Blob & Get () const
Static Private Member Functions
static void Copy (const PropertyValue &prop0Val, PropertyValue &prop1Val)
Private Attributes
DataType dataType
union {
   bool   boolVal
   int   intVal
   unsigned int   uintVal
   float   floatVal
   double   doubleVal
   unsigned long long   ulonglongVal
   std::string *   stringVal
   Blob *   blobVal
} data
Detailed Description
The current list of allowed data types is:
  • bool
  • int
  • unsigned int
  • float
  • double
  • unsigned long long
  • string
  • Blob
Definition at line 82 of file properties.h.
Member Enumeration Documentation
Enumerator
NONE_VAL
BOOL_VAL
INT_VAL
UINT_VAL
FLOAT_VAL
DOUBLE_VAL
ULONGLONG_VAL
STRING_VAL
BLOB_VAL
Definition at line 84 of file properties.h.
Constructor & Destructor Documentation
luxrays::PropertyValue::PropertyValue ( )
luxrays::PropertyValue::PropertyValue ( const PropertyValue &  propVal)
luxrays::PropertyValue::PropertyValue ( const bool  val)
luxrays::PropertyValue::PropertyValue ( const int  val)
luxrays::PropertyValue::PropertyValue ( const unsigned int  val)
luxrays::PropertyValue::PropertyValue ( const float  val)
luxrays::PropertyValue::PropertyValue ( const double  val)
luxrays::PropertyValue::PropertyValue ( const unsigned long long  val)
luxrays::PropertyValue::PropertyValue ( const std::string &  val)
luxrays::PropertyValue::PropertyValue ( const Blob &  val)
luxrays::PropertyValue::~PropertyValue ( )
Member Function Documentation
static void luxrays::PropertyValue::Copy ( const PropertyValue &  prop0Val,
PropertyValue &  prop1Val
staticprivate
template<class T >
T luxrays::PropertyValue::Get ( ) const
template<>
CPP_API bool luxrays::PropertyValue::Get ( ) const
template<>
CPP_API int luxrays::PropertyValue::Get ( ) const
template<>
CPP_API unsigned int luxrays::PropertyValue::Get ( ) const
template<>
CPP_API float luxrays::PropertyValue::Get ( ) const
template<>
CPP_API double luxrays::PropertyValue::Get ( ) const
template<>
CPP_API unsigned long long luxrays::PropertyValue::Get ( ) const
template<>
CPP_API const Blob& luxrays::PropertyValue::Get ( ) const
DataType luxrays::PropertyValue::GetValueType ( ) const
PropertyValue& luxrays::PropertyValue::operator= ( const PropertyValue &  propVal)
Member Data Documentation
Blob* luxrays::PropertyValue::blobVal
Definition at line 127 of file properties.h.
bool luxrays::PropertyValue::boolVal
Definition at line 120 of file properties.h.
union { ... } luxrays::PropertyValue::data
DataType luxrays::PropertyValue::dataType
private
Definition at line 117 of file properties.h.
double luxrays::PropertyValue::doubleVal
Definition at line 124 of file properties.h.
float luxrays::PropertyValue::floatVal
Definition at line 123 of file properties.h.
int luxrays::PropertyValue::intVal
Definition at line 121 of file properties.h.
std::string* luxrays::PropertyValue::stringVal
Definition at line 126 of file properties.h.
unsigned int luxrays::PropertyValue::uintVal
Definition at line 122 of file properties.h.
unsigned long long luxrays::PropertyValue::ulonglongVal
Definition at line 125 of file properties.h.
The documentation for this class was generated from the following file:
