LuxCore  2.0
 All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Macros
luxcore::Scene Class Referenceabstract
Scene stores textures, materials and objects definitions. More...
#include <luxcore.h>
Public Types
enum  ChannelSelectionType {
  DEFAULT, RED, GREEN, BLUE,
  ALPHA, MEAN, WEIGHTED_MEAN, RGB
 Types of image map channel selection. More...
enum  WrapType { REPEAT, BLACK, WHITE, CLAMP }
 Types of image map wrap mode. More...
enum  StrandsTessellationType { TESSEL_RIBBON, TESSEL_RIBBON_ADAPTIVE, TESSEL_SOLID, TESSEL_SOLID_ADAPTIVE }
 Types of strands tessellation. More...
Public Member Functions
virtual ~Scene ()
virtual void GetBBox (float min[3], float max[3]) const =0
 Returns the bounding box of the complete scene (as minimum and maximum point). It is available only during the rendering (i.e. after a RenderSession::Start()). More...
virtual const Camera & GetCamera () const =0
 Returns the Camera of the scene. More...
template<class T >
void DefineImageMap (const std::string &imgMapName, T *pixels, const float gamma, const unsigned int channels, const unsigned int width, const unsigned int height, ChannelSelectionType selectionType=DEFAULT, WrapType wrapType=REPEAT)
 Defines an image map (to be later used in textures, infinite lights, etc.). The memory allocated for pixels array is NOT freed by the Scene class nor is used after the execution of this method. The types supported are "unsigned char", "unsigned short" (as a place holder for half type) and "float". More...
virtual bool IsImageMapDefined (const std::string &imgMapName) const =0
 Check if an image map with the given name has been defined. More...
virtual void SetDeleteMeshData (const bool v)=0
 Sets if the Scene class destructor will delete the arrays pointed to by the defined meshes. More...
virtual void DefineMesh (const std::string &meshName, const long plyNbVerts, const long plyNbTris, float *p, unsigned int *vi, float *n, float *uv, float *cols, float *alphas)=0
 Defines a mesh (to be later used in one or more scene objects). The memory allocated for the ExtTriangleMesh is always freed by the Scene class, however freeing of memory for the vertices, triangle indices, etc. depends on the setting of SetDeleteMeshData(). NOTE: vertices and triangles buffers MUST be allocated with Scene::AllocVerticesBuffer() and Scene::AllocTrianglesBuffer(). More...
virtual void SaveMesh (const std::string &meshName, const std::string &fileName)=0
 Save a previously defined mesh to file system in PLY or BPY format. More...
virtual void DefineStrands (const std::string &shapeName, const luxrays::cyHairFile &strandsFile, const StrandsTessellationType tesselType, const unsigned int adaptiveMaxDepth, const float adaptiveError, const unsigned int solidSideCount, const bool solidCapBottom, const bool solidCapTop, const bool useCameraPosition)=0
 Defines a mesh (to be later used in one or more scene objects) starting from the strands/hairs definition included in strandsFile. More...
virtual bool IsMeshDefined (const std::string &meshName) const =0
 Check if a mesh with the given name has been defined. More...
virtual bool IsTextureDefined (const std::string &texName) const =0
 Check if a texture with the given name has been defined. More...
virtual bool IsMaterialDefined (const std::string &matName) const =0
 Check if a material with the given name has been defined. More...
virtual const unsigned int GetLightCount () const =0
 Returns the number of light sources in the Scene. More...
virtual const unsigned int GetObjectCount () const =0
 Returns the number of objects in the Scene. More...
virtual void Parse (const luxrays::Properties &props)=0
 Edits or creates camera, textures, materials and/or objects based on the Properties defined. If the scene is in use by a RenderSession, it must be called between a RenderSession::BeginSceneEdit() and RenderSession::EndSceneEdit(). More...
virtual void DuplicateObject (const std::string &srcObjName, const std::string &dstObjName, const float *transMat)=0
 Duplicate an object in an instance using the passed transformation. More...
virtual void DuplicateObject (const std::string &srcObjName, const std::string &dstObjNamePrefix, const unsigned int count, const float *transMat)=0
 Duplicate an object multiple times in instances using the passed transformations. Mostly useful for fast creating many copies of the same object (for instance for particles). More...
virtual void DuplicateObject (const std::string &srcObjName, const std::string &dstObjName, const unsigned int steps, const float *times, const float *transMat)=0
 Duplicate an object in a motion blur instance using the passed transformation. More...
virtual void DuplicateObject (const std::string &srcObjName, const std::string &dstObjNamePrefix, const unsigned int count, const unsigned int steps, const float *times, const float *transMat)=0
 Duplicate an object multiple times in a motion blur instance using the passed transformations. Mostly useful for fast creating many copies of the same object (for instance for particles). More...
virtual void UpdateObjectTransformation (const std::string &objName, const float *transMat)=0
 Apply a transformation to an object. More...
virtual void UpdateObjectMaterial (const std::string &objName, const std::string &matName)=0
 Apply a new material to an object. More...
virtual void DeleteObject (const std::string &objName)=0
 Deletes an object from the scene. More...
virtual void DeleteLight (const std::string &lightName)=0
 Deletes a light from the scene. More...
virtual void RemoveUnusedImageMaps ()=0
 Removes all unused image maps. More...
virtual void RemoveUnusedTextures ()=0
 Removes all unused textures. More...
virtual void RemoveUnusedMaterials ()=0
 Removes all unused materials. More...
virtual void RemoveUnusedMeshes ()=0
 Removes all unused meshes. More...
virtual const luxrays::Properties & ToProperties () const =0
 Returns all the Properties required to define this Scene. More...
virtual void Save (const std::string &fileName) const =0
 Serializes a Scene in a file. More...
template<>
void CPP_API DefineImageMap (const std::string &imgMapName, unsigned char *pixels, const float gamma, const unsigned int channels, const unsigned int width, const unsigned int height, Scene::ChannelSelectionType selectionType, Scene::WrapType wrapType)
template<>
void CPP_API DefineImageMap (const std::string &imgMapName, unsigned short *pixels, const float gamma, const unsigned int channels, const unsigned int width, const unsigned int height, Scene::ChannelSelectionType selectionType, Scene::WrapType wrapType)
template<>
void CPP_API DefineImageMap (const std::string &imgMapName, float *pixels, const float gamma, const unsigned int channels, const unsigned int width, const unsigned int height, Scene::ChannelSelectionType selectionType, Scene::WrapType wrapType)
Static Public Member Functions
static Scene * Create (const float imageScale=1.f)
 Create a new empty Scene. More...
static Scene * Create (const luxrays::Properties &props, const float imageScale=1.f)
 Creates a new Scene as defined by props. More...
static Scene * Create (const std::string &fileName, const float imageScale=1.f)
 Creates a new Scene as defined in fileName file. More...
static float * AllocVerticesBuffer (const unsigned int meshVertCount)
 This must be used to allocate Mesh vertices buffer. More...
static unsigned int * AllocTrianglesBuffer (const unsigned int meshTriCount)
 This must be used to allocate Mesh triangles buffer. More...
Protected Member Functions
virtual void DefineImageMapUChar (const std::string &imgMapName, unsigned char *pixels, const float gamma, const unsigned int channels, const unsigned int width, const unsigned int height, ChannelSelectionType selectionType, WrapType wrapType)=0
virtual void DefineImageMapHalf (const std::string &imgMapName, unsigned short *pixels, const float gamma, const unsigned int channels, const unsigned int width, const unsigned int height, ChannelSelectionType selectionType, WrapType wrapType)=0
virtual void DefineImageMapFloat (const std::string &imgMapName, float *pixels, const float gamma, const unsigned int channels, const unsigned int width, const unsigned int height, ChannelSelectionType selectionType, WrapType wrapType)=0
Detailed Description
Definition at line 544 of file luxcore.h.
Member Enumeration Documentation
Enumerator
DEFAULT
RED
GREEN
BLUE
ALPHA
MEAN
WEIGHTED_MEAN
RGB
Definition at line 549 of file luxcore.h.
Enumerator
TESSEL_RIBBON
TESSEL_SOLID
Definition at line 573 of file luxcore.h.
Enumerator
REPEAT
BLACK
WHITE
CLAMP
Definition at line 563 of file luxcore.h.
Constructor & Destructor Documentation
virtual luxcore::Scene::~Scene ( )
virtual
Member Function Documentation
static unsigned int* luxcore::Scene::AllocTrianglesBuffer ( const unsigned int  meshTriCount)
static
static float* luxcore::Scene::AllocVerticesBuffer ( const unsigned int  meshVertCount)
static
static Scene* luxcore::Scene::Create ( const float  imageScale = 1.f)
static
Parameters
imageScaledefines the scale used for storing any kind of image in memory.
static Scene* luxcore::Scene::Create ( const luxrays::Properties &  props,
static
Parameters
propsare the Properties used to build the new Scene.
static Scene* luxcore::Scene::Create ( const std::string &  fileName,
static
Parameters
fileNameis the name of the file with the scene description to read. It can be a text SDL file or a serialized binary file. The extension for the binary format must be ".bsc".
imageScaledefines the scale used for storing any kind of image in memory. This parameter has no effect when loading binary serialized binary file.
template<class T >
void luxcore::Scene::DefineImageMap ( const std::string &  imgMapName,
T *  pixels,
const float  gamma,
ChannelSelectionType  selectionType = DEFAULT,
WrapType  wrapType = REPEAT
inline
Parameters
imgMapNameis the name of the defined image map.
pixelsis a pointer to an array of image map pixels.
gammais the gamma correction value of the image.
channelsis the number of data used for each pixel (1 or 3).
widthis the width of the image map.
heightis the height of the image map.
Definition at line 634 of file luxcore.h.
template<>
void CPP_API luxcore::Scene::DefineImageMap ( const std::string &  imgMapName,
unsigned char *  pixels,
const float  gamma,
template<>
unsigned short *  pixels,
const float  gamma,
template<>
float *  pixels,
const float  gamma,
virtual void luxcore::Scene::DefineImageMapFloat ( const std::string &  imgMapName,
float *  pixels,
const float  gamma,
WrapType  wrapType
protectedpure virtual
virtual void luxcore::Scene::DefineImageMapHalf ( const std::string &  imgMapName,
const float  gamma,
WrapType  wrapType
virtual void luxcore::Scene::DefineImageMapUChar ( const std::string &  imgMapName,
const float  gamma,
WrapType  wrapType
virtual void luxcore::Scene::DefineMesh ( const std::string &  meshName,
float *  p,
unsigned int *  vi,
float *  n,
float *  uv,
float *  cols,
float *  alphas
pure virtual
Parameters
meshNameis the name of the defined mesh.
plyNbVertsis the number of mesh vertices.
plyNbTrisis the number of mesh triangles.
pis a pointer to an array of vertices. Embree accelerator has a very special requirement. The 4 bytes after the z-coordinate of the last vertex have to be readable memory, thus padding is required.
viis a pointer to an array of triangles.
nis a pointer to an array of normals. It can be NULL.
uvis a pointer to an array of UV coordinates. It can be NULL.
colsis a pointer to an array of vertices colors. It can be NULL.
alphasis a pointer to an array of vertices alphas. It can be NULL.
virtual void luxcore::Scene::DefineStrands ( const std::string &  shapeName,
const luxrays::cyHairFile &  strandsFile,
pure virtual
Parameters
shapeNameis the name of the defined shape.
strandsFileincludes all information about the strands .
tesselTypeis the tessellation used to transform the strands in a triangle mesh.
adaptiveMaxDepthis maximum number of subdivisions for adaptive tessellation.
adaptiveErroris the error threshold for adaptive tessellation.
solidSideCountis the number of sides for solid tessellation.
solidCapBottomis a flag to set if strands has to have a bottom cap.
solidCapTopis a flag to set if strands has to have a top cap.
useCameraPositionis a flag to set if ribbon tessellation has to be faced toward the camera.
virtual void luxcore::Scene::DeleteLight ( const std::string &  lightName)
pure virtual
Parameters
lightNameis the name of the object to delete. Note: to delete area lights, use DeleteObject().
virtual void luxcore::Scene::DeleteObject ( const std::string &  objName)
pure virtual
Parameters
objNameis the name of the object to delete.
virtual void luxcore::Scene::DuplicateObject ( const std::string &  srcObjName,
const std::string &  dstObjName,
const float *  transMat
pure virtual
Parameters
srcObjNameis the name of the object to duplicate.
dstObjNameis the name of the object to create.
transMatis the transformation 4x4 matrix to use.
const std::string &  dstObjNamePrefix,
pure virtual
Parameters
dstObjNamePrefixis the prefix of the names of the object to create. The number of the copy will be appended.
countis the number of the object to create.
transMatis an array of transformation 4x4 matrices to use.
const float *  times,
pure virtual
Parameters
stepsis the number of motion blur steps.
timesis an array of times to use
transMatis an array of the transformation 4x4 matrix to use.
pure virtual
Parameters
dstObjNamePrefixis the name of the object to create.
virtual void luxcore::Scene::GetBBox ( float  min[3],
float  max[3]
) const
pure virtual
virtual const Camera& luxcore::Scene::GetCamera ( ) const
pure virtual
Returns
a reference to the Camera of this Scene. It is available only during the rendering (i.e. after a RenderSession::Start()).
virtual const unsigned int luxcore::Scene::GetLightCount ( ) const
pure virtual
Returns
virtual const unsigned int luxcore::Scene::GetObjectCount ( ) const
pure virtual
Returns
virtual bool luxcore::Scene::IsImageMapDefined ( const std::string &  imgMapName) const
pure virtual
Parameters
imgMapNameis the name to check.
Returns
true if the image map has been defined, false otherwise.
virtual bool luxcore::Scene::IsMaterialDefined ( const std::string &  matName) const
pure virtual
Parameters
matNameis the name to check.
Returns
true if the material has been defined, false otherwise.
virtual bool luxcore::Scene::IsMeshDefined ( const std::string &  meshName) const
pure virtual
Parameters
meshNameis the name to check.
Returns
true if the mesh has been defined, false otherwise.
virtual bool luxcore::Scene::IsTextureDefined ( const std::string &  texName) const
pure virtual
Parameters
texNameis the name to check.
Returns
true if the texture has been defined, false otherwise.
virtual void luxcore::Scene::Parse ( const luxrays::Properties &  props)
pure virtual
Parameters
propsare the Properties with the definition of camera, textures, materials and/or objects.
virtual void luxcore::Scene::RemoveUnusedImageMaps ( )
pure virtual
virtual void luxcore::Scene::RemoveUnusedMaterials ( )
pure virtual
virtual void luxcore::Scene::RemoveUnusedMeshes ( )
pure virtual
virtual void luxcore::Scene::RemoveUnusedTextures ( )
pure virtual
virtual void luxcore::Scene::Save ( const std::string &  fileName) const
pure virtual
Parameters
fileNameis the name of the file where to serialize the scene.
virtual void luxcore::Scene::SaveMesh ( const std::string &  meshName,
pure virtual
Parameters
meshNameis the name of the defined mesh to be saved.
fileNameis the name of the file where to save the mesh. If it has the extension ".ply", the text PLY format will be used. If it has the extension ".bpy", the text PLY format will be used.
virtual void luxcore::Scene::SetDeleteMeshData ( const bool  v)
pure virtual
Parameters
vdefines if the Scene class destructor will delete the mesh data.
virtual const luxrays::Properties& luxcore::Scene::ToProperties ( ) const
pure virtual
Returns
a reference to the Properties of this Scene.
virtual void luxcore::Scene::UpdateObjectMaterial ( const std::string &  objName,
pure virtual
Parameters
objNameis the name of the object to apply the material to.
matNameis the new material name.
virtual void luxcore::Scene::UpdateObjectTransformation ( const std::string &  objName,
pure virtual
Parameters
objNameis the name of the object to transform.
transMatis the transformation 4x4 matrix to apply.
The documentation for this class was generated from the following file:
