LuxCore  2.0
 All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Macros
luxcore::Film Class Referenceabstract
Film stores all the outputs of a rendering. It can be obtained from a RenderSession or as stand alone object loaded from a file. More...
#include <luxcore.h>
Public Types
enum  FilmOutputType {
  OUTPUT_RGB, OUTPUT_RGBA, OUTPUT_RGB_IMAGEPIPELINE, OUTPUT_RGBA_IMAGEPIPELINE,
  OUTPUT_ALPHA, OUTPUT_DEPTH, OUTPUT_POSITION, OUTPUT_GEOMETRY_NORMAL,
  OUTPUT_SHADING_NORMAL, OUTPUT_MATERIAL_ID, OUTPUT_DIRECT_DIFFUSE, OUTPUT_DIRECT_GLOSSY,
  OUTPUT_EMISSION, OUTPUT_INDIRECT_DIFFUSE, OUTPUT_INDIRECT_GLOSSY, OUTPUT_INDIRECT_SPECULAR,
  OUTPUT_MATERIAL_ID_MASK, OUTPUT_DIRECT_SHADOW_MASK, OUTPUT_INDIRECT_SHADOW_MASK, OUTPUT_RADIANCE_GROUP,
  OUTPUT_UV, OUTPUT_RAYCOUNT, OUTPUT_BY_MATERIAL_ID, OUTPUT_IRRADIANCE,
  OUTPUT_OBJECT_ID, OUTPUT_OBJECT_ID_MASK, OUTPUT_BY_OBJECT_ID, OUTPUT_FRAMEBUFFER_MASK,
  OUTPUT_SAMPLECOUNT, OUTPUT_CONVERGENCE
 Types of Film channel available. More...
enum  FilmChannelType {
  CHANNEL_RADIANCE_PER_PIXEL_NORMALIZED = 1 << 0, CHANNEL_RADIANCE_PER_SCREEN_NORMALIZED = 1 << 1, CHANNEL_ALPHA = 1 << 2, CHANNEL_IMAGEPIPELINE = 1 << 3,
  CHANNEL_DEPTH = 1 << 4, CHANNEL_POSITION = 1 << 5, CHANNEL_GEOMETRY_NORMAL = 1 << 6, CHANNEL_SHADING_NORMAL = 1 << 7,
  CHANNEL_MATERIAL_ID = 1 << 8, CHANNEL_DIRECT_DIFFUSE = 1 << 9, CHANNEL_DIRECT_GLOSSY = 1 << 10, CHANNEL_EMISSION = 1 << 11,
  CHANNEL_INDIRECT_DIFFUSE = 1 << 12, CHANNEL_INDIRECT_GLOSSY = 1 << 13, CHANNEL_INDIRECT_SPECULAR = 1 << 14, CHANNEL_MATERIAL_ID_MASK = 1 << 15,
  CHANNEL_DIRECT_SHADOW_MASK = 1 << 16, CHANNEL_INDIRECT_SHADOW_MASK = 1 << 17, CHANNEL_UV = 1 << 18, CHANNEL_RAYCOUNT = 1 << 19,
  CHANNEL_BY_MATERIAL_ID = 1 << 20, CHANNEL_IRRADIANCE = 1 << 21, CHANNEL_OBJECT_ID = 1 << 22, CHANNEL_OBJECT_ID_MASK = 1 << 23,
  CHANNEL_BY_OBJECT_ID = 1 << 24, CHANNEL_FRAMEBUFFER_MASK = 1 << 25, CHANNEL_SAMPLECOUNT = 1 << 26, CHANNEL_CONVERGENCE = 1 << 27
Public Member Functions
virtual ~Film ()
virtual unsigned int GetWidth () const =0
 Returns the Film width. More...
virtual unsigned int GetHeight () const =0
 Returns the Film height. More...
virtual luxrays::Properties GetStats () const =0
 Returns a list of statistics related to the film. Mostly useful for stand alone films. More...
virtual float GetFilmY (const unsigned int imagePipelineIndex=0) const =0
 Returns the Film average luminance. It can be used to estimate a good value for variance clamping. More...
virtual void Clear ()=0
 Clear the film. More...
virtual void AddFilm (const Film &film)=0
 Add a film. More...
virtual void AddFilm (const Film &film, const unsigned int srcOffsetX, const unsigned int srcOffsetY, const unsigned int srcWidth, const unsigned int srcHeight, const unsigned int dstOffsetX, const unsigned int dstOffsetY)=0
 Add a film. More...
virtual void SaveOutputs () const =0
 Saves all Film output channels defined in the current RenderSession. This method can not be used with a standalone film. More...
virtual void SaveOutput (const std::string &fileName, const FilmOutputType type, const luxrays::Properties &props) const =0
 Saves the specified Film output channels. More...
virtual void SaveFilm (const std::string &fileName) const =0
 Serializes a Film in a file. More...
virtual double GetTotalSampleCount () const =0
 Returns the total sample count. More...
virtual size_t GetOutputSize (const FilmOutputType type) const =0
 Returns the size (in float or unsigned int) of a Film output channel. More...
virtual bool HasOutput (const FilmOutputType type) const =0
 Returns if a film channel output is available. More...
virtual unsigned int GetOutputCount (const FilmOutputType type) const =0
 Returns the number of output channels of the passed type. More...
virtual unsigned int GetRadianceGroupCount () const =0
 Returns the number of radiance groups. More...
template<class T >
void GetOutput (const FilmOutputType type, T *buffer, const unsigned int index=0)
 Fills the buffer with a Film output channel. More...
virtual bool HasChannel (const FilmChannelType type) const =0
 Returns if a film channel is available. More...
virtual unsigned int GetChannelCount (const FilmChannelType type) const =0
 Returns the number of channels of the passed type. More...
template<class T >
const T * GetChannel (const FilmChannelType type, const unsigned int index=0)
 Returns a pointer to the type of channel requested. The channel is not normalized (if it has a weight channel). More...
virtual void Parse (const luxrays::Properties &props)=0
 Sets configuration Properties with new values. This method can be used only when the Film is not in use by a RenderSession. Image pipeline and radiance scale values can be redefined with this method. More...
virtual void DeleteAllImagePipelines ()=0
 Delete all image pipelines and goes the default image pipeline (AutoLinearToneMap + GammaCorrectionPlugin). This method can be used with a stand alone film or with a session film. More...
template<>
CPP_API void GetOutput (const FilmOutputType type, float *buffer, const unsigned int index)
template<>
CPP_API void GetOutput (const FilmOutputType type, unsigned int *buffer, const unsigned int index)
template<>
CPP_API const float * GetChannel (const FilmChannelType type, const unsigned int index)
template<>
CPP_API const unsigned int * GetChannel (const FilmChannelType type, const unsigned int index)
Static Public Member Functions
static Film * Create (const std::string &fileName)
 Loads a stand alone Film (i.e. not connected to a rendering session) from a file. More...
static Film * Create (const luxrays::Properties &props, const bool hasPixelNormalizedChannel, const bool hasScreenNormalizedChannel)
 Create a stand alone Film (i.e. not connected to a rendering session) from the properties. More...
Protected Member Functions
virtual void GetOutputFloat (const FilmOutputType type, float *buffer, const unsigned int index)=0
virtual void GetOutputUInt (const FilmOutputType type, unsigned int *buffer, const unsigned int index)=0
virtual const float * GetChannelFloat (const FilmChannelType type, const unsigned int index)=0
virtual const unsigned int * GetChannelUInt (const FilmChannelType type, const unsigned int index)=0
Detailed Description
Definition at line 150 of file luxcore.h.
Member Enumeration Documentation
Enumerator
CHANNEL_ALPHA
CHANNEL_DEPTH
CHANNEL_POSITION
CHANNEL_MATERIAL_ID
CHANNEL_EMISSION
CHANNEL_UV
CHANNEL_RAYCOUNT
CHANNEL_IRRADIANCE
CHANNEL_OBJECT_ID
CHANNEL_SAMPLECOUNT
CHANNEL_CONVERGENCE
Definition at line 192 of file luxcore.h.
Enumerator
OUTPUT_RGB
OUTPUT_RGBA
OUTPUT_ALPHA
OUTPUT_DEPTH
OUTPUT_POSITION
OUTPUT_MATERIAL_ID
OUTPUT_EMISSION
OUTPUT_UV
OUTPUT_RAYCOUNT
OUTPUT_IRRADIANCE
OUTPUT_OBJECT_ID
OUTPUT_BY_OBJECT_ID
OUTPUT_SAMPLECOUNT
OUTPUT_CONVERGENCE
Definition at line 155 of file luxcore.h.
Constructor & Destructor Documentation
virtual luxcore::Film::~Film ( )
virtual
Member Function Documentation
virtual void luxcore::Film::AddFilm ( const Film &  film)
pure virtual
Add a film.
Parameters
filmthe film to add.
virtual void luxcore::Film::AddFilm ( const Film &  film,
pure virtual
Add a film.
Parameters
srcOffsetXthe X offset of the region of the film to add.
srcOffsetYthe y offset of the region of the film to add.
srcWidththe width of the region of the film to add.
srcHeightthe height of the region of the film to add.
dstOffsetXthe X offset of the destination film.
dstOffsetYthe Y offset of the destination film.
virtual void luxcore::Film::Clear ( )
pure virtual
Clear the film.
static Film* luxcore::Film::Create ( const std::string &  fileName)
static
Parameters
fileNameis the name of the file with the serialized film to read.
static Film* luxcore::Film::Create ( const luxrays::Properties &  props,
static
Parameters
propsdefining the film.
hasPixelNormalizedChannelif the film must have CHANNEL_RADIANCE_PER_PIXEL_NORMALIZED. Required by all render engines.
hasScreenNormalizedChannelif the film must have CHANNEL_RADIANCE_PER_SCREEN_NORMALIZED. Required by BIDIRCPU and LIGHTCPU render engines.
virtual void luxcore::Film::DeleteAllImagePipelines ( )
pure virtual
template<class T >
const T* luxcore::Film::GetChannel ( const FilmChannelType  type,
const unsigned int  index = 0
inline
Parameters
typeis the Film output channel to return. It must be one of the enabled channels in RenderConfig. The supported template types are float and unsigned int.
indexof the buffer to use. Usually 0, however, for instance, if more than one light group is used, select the group to return.
Returns
a pointer to the requested raw buffer.
Definition at line 409 of file luxcore.h.
template<>
CPP_API const float* luxcore::Film::GetChannel ( const FilmChannelType  type,
template<>
CPP_API const unsigned int* luxcore::Film::GetChannel ( const FilmChannelType  type,
virtual unsigned int luxcore::Film::GetChannelCount ( const FilmChannelType  type) const
pure virtual
Parameters
typeis the Film channel to use.
Returns
the number of channels. Returns 0 if the channel is not available.
virtual const float* luxcore::Film::GetChannelFloat ( const FilmChannelType  type,
protectedpure virtual
virtual const unsigned int* luxcore::Film::GetChannelUInt ( const FilmChannelType  type,
virtual float luxcore::Film::GetFilmY ( const unsigned int  imagePipelineIndex = 0) const
pure virtual
Parameters
imagePipelineIndexthe index of the image pipeline radiance group scale to use.
Returns
virtual unsigned int luxcore::Film::GetHeight ( ) const
pure virtual
Returns
the Film width.
template<class T >
void luxcore::Film::GetOutput ( const FilmOutputType  type,
T *  buffer,
inline
Parameters
typeis the Film output channel to use. It must be one of the enabled channels in RenderConfig. The supported template types are float and unsigned int.
bufferis the place where the data will be copied.
Definition at line 378 of file luxcore.h.
template<>
CPP_API void luxcore::Film::GetOutput ( const FilmOutputType  type,
float *  buffer,
template<>
unsigned int *  buffer,
virtual unsigned int luxcore::Film::GetOutputCount ( const FilmOutputType  type) const
pure virtual
Parameters
Returns
the number of output channels. Returns 0 if the output channel is not available.
virtual void luxcore::Film::GetOutputFloat ( const FilmOutputType  type,
float *  buffer,
virtual size_t luxcore::Film::GetOutputSize ( const FilmOutputType  type) const
pure virtual
Parameters
Returns
virtual void luxcore::Film::GetOutputUInt ( const FilmOutputType  type,
virtual unsigned int luxcore::Film::GetRadianceGroupCount ( ) const
pure virtual
Returns
virtual luxrays::Properties luxcore::Film::GetStats ( ) const
pure virtual
Returns
a Properties container with the statistics.
virtual double luxcore::Film::GetTotalSampleCount ( ) const
pure virtual
Returns
virtual unsigned int luxcore::Film::GetWidth ( ) const
pure virtual
Returns
the Film width.
virtual bool luxcore::Film::HasChannel ( const FilmChannelType  type) const
pure virtual
Parameters
Returns
true if the output is available, false otherwise.
virtual bool luxcore::Film::HasOutput ( const FilmOutputType  type) const
pure virtual
Parameters
Returns
virtual void luxcore::Film::Parse ( const luxrays::Properties &  props)
pure virtual
Parameters
propsare the Properties to set.
virtual void luxcore::Film::SaveFilm ( const std::string &  fileName) const
pure virtual
Parameters
fileNameis the name of the file where to serialize the film.
virtual void luxcore::Film::SaveOutput ( const std::string &  fileName,
) const
pure virtual
Parameters
fileNameis the name of the file where to save the output channel.
typeis the Film output channel to use. It must be one of the enabled channels.
propscan include some additional information defined by the following property: "id" for the ID of MATERIAL_ID_MASK, "id" for the index of RADIANCE_GROUP, "id" for the ID of BY_MATERIAL_ID. "id" for the ID of OBJECT_ID_MASK, "id" for the ID of BY_OBJECT_ID.
virtual void luxcore::Film::SaveOutputs ( ) const
pure virtual
The documentation for this class was generated from the following file:
