| AddFilm(const Film &film)=0 | luxcore::Film | pure virtual |
| AddFilm(const Film &film, const unsigned int srcOffsetX, const unsigned int srcOffsetY, const unsigned int srcWidth, const unsigned int srcHeight, const unsigned int dstOffsetX, const unsigned int dstOffsetY)=0 | luxcore::Film | pure virtual |
| CHANNEL_ALPHA enum value | luxcore::Film | |
| CHANNEL_BY_MATERIAL_ID enum value | luxcore::Film | |
| CHANNEL_BY_OBJECT_ID enum value | luxcore::Film | |
| CHANNEL_CONVERGENCE enum value | luxcore::Film | |
| CHANNEL_DEPTH enum value | luxcore::Film | |
| CHANNEL_DIRECT_DIFFUSE enum value | luxcore::Film | |
| CHANNEL_DIRECT_GLOSSY enum value | luxcore::Film | |
| CHANNEL_DIRECT_SHADOW_MASK enum value | luxcore::Film | |
| CHANNEL_EMISSION enum value | luxcore::Film | |
| CHANNEL_FRAMEBUFFER_MASK enum value | luxcore::Film | |
| CHANNEL_GEOMETRY_NORMAL enum value | luxcore::Film | |
| CHANNEL_IMAGEPIPELINE enum value | luxcore::Film | |
| CHANNEL_INDIRECT_DIFFUSE enum value | luxcore::Film | |
| CHANNEL_INDIRECT_GLOSSY enum value | luxcore::Film | |
| CHANNEL_INDIRECT_SHADOW_MASK enum value | luxcore::Film | |
| CHANNEL_INDIRECT_SPECULAR enum value | luxcore::Film | |
| CHANNEL_IRRADIANCE enum value | luxcore::Film | |
| CHANNEL_MATERIAL_ID enum value | luxcore::Film | |
| CHANNEL_MATERIAL_ID_MASK enum value | luxcore::Film | |
| CHANNEL_OBJECT_ID enum value | luxcore::Film | |
| CHANNEL_OBJECT_ID_MASK enum value | luxcore::Film | |
| CHANNEL_POSITION enum value | luxcore::Film | |
| CHANNEL_RADIANCE_PER_PIXEL_NORMALIZED enum value | luxcore::Film | |
| CHANNEL_RADIANCE_PER_SCREEN_NORMALIZED enum value | luxcore::Film | |
| CHANNEL_RAYCOUNT enum value | luxcore::Film | |
| CHANNEL_SAMPLECOUNT enum value | luxcore::Film | |
| CHANNEL_SHADING_NORMAL enum value | luxcore::Film | |
| CHANNEL_UV enum value | luxcore::Film | |
| Clear()=0 | luxcore::Film | pure virtual |
| Create(const std::string &fileName) | luxcore::Film | static |
| Create(const luxrays::Properties &props, const bool hasPixelNormalizedChannel, const bool hasScreenNormalizedChannel) | luxcore::Film | static |
| DeleteAllImagePipelines()=0 | luxcore::Film | pure virtual |
| FilmChannelType enum name | luxcore::Film | |
| FilmOutputType enum name | luxcore::Film | |
| GetChannel(const FilmChannelType type, const unsigned int index=0) | luxcore::Film | inline |
| GetChannel(const FilmChannelType type, const unsigned int index) | luxcore::Film | |
| GetChannelCount(const FilmChannelType type) const =0 | luxcore::Film | pure virtual |
| GetChannelFloat(const FilmChannelType type, const unsigned int index)=0 | luxcore::Film | protectedpure virtual |
| GetChannelUInt(const FilmChannelType type, const unsigned int index)=0 | luxcore::Film | protectedpure virtual |
| GetFilmY(const unsigned int imagePipelineIndex=0) const =0 | luxcore::Film | pure virtual |
| GetHeight() const =0 | luxcore::Film | pure virtual |
| GetOutput(const FilmOutputType type, T *buffer, const unsigned int index=0) | luxcore::Film | inline |
| GetOutput(const FilmOutputType type, float *buffer, const unsigned int index) | luxcore::Film | |
| GetOutput(const FilmOutputType type, unsigned int *buffer, const unsigned int index) | luxcore::Film | |
| GetOutputCount(const FilmOutputType type) const =0 | luxcore::Film | pure virtual |
| GetOutputFloat(const FilmOutputType type, float *buffer, const unsigned int index)=0 | luxcore::Film | protectedpure virtual |
| GetOutputSize(const FilmOutputType type) const =0 | luxcore::Film | pure virtual |
| GetOutputUInt(const FilmOutputType type, unsigned int *buffer, const unsigned int index)=0 | luxcore::Film | protectedpure virtual |
| GetRadianceGroupCount() const =0 | luxcore::Film | pure virtual |
| GetStats() const =0 | luxcore::Film | pure virtual |
| GetTotalSampleCount() const =0 | luxcore::Film | pure virtual |
| GetWidth() const =0 | luxcore::Film | pure virtual |
| HasChannel(const FilmChannelType type) const =0 | luxcore::Film | pure virtual |
| HasOutput(const FilmOutputType type) const =0 | luxcore::Film | pure virtual |
| OUTPUT_ALPHA enum value | luxcore::Film | |
| OUTPUT_BY_MATERIAL_ID enum value | luxcore::Film | |
| OUTPUT_BY_OBJECT_ID enum value | luxcore::Film | |
| OUTPUT_CONVERGENCE enum value | luxcore::Film | |
| OUTPUT_DEPTH enum value | luxcore::Film | |
| OUTPUT_DIRECT_DIFFUSE enum value | luxcore::Film | |
| OUTPUT_DIRECT_GLOSSY enum value | luxcore::Film | |
| OUTPUT_DIRECT_SHADOW_MASK enum value | luxcore::Film | |
| OUTPUT_EMISSION enum value | luxcore::Film | |
| OUTPUT_FRAMEBUFFER_MASK enum value | luxcore::Film | |
| OUTPUT_GEOMETRY_NORMAL enum value | luxcore::Film | |
| OUTPUT_INDIRECT_DIFFUSE enum value | luxcore::Film | |
| OUTPUT_INDIRECT_GLOSSY enum value | luxcore::Film | |
| OUTPUT_INDIRECT_SHADOW_MASK enum value | luxcore::Film | |
| OUTPUT_INDIRECT_SPECULAR enum value | luxcore::Film | |
| OUTPUT_IRRADIANCE enum value | luxcore::Film | |
| OUTPUT_MATERIAL_ID enum value | luxcore::Film | |
| OUTPUT_MATERIAL_ID_MASK enum value | luxcore::Film | |
| OUTPUT_OBJECT_ID enum value | luxcore::Film | |
| OUTPUT_OBJECT_ID_MASK enum value | luxcore::Film | |
| OUTPUT_POSITION enum value | luxcore::Film | |
| OUTPUT_RADIANCE_GROUP enum value | luxcore::Film | |
| OUTPUT_RAYCOUNT enum value | luxcore::Film | |
| OUTPUT_RGB enum value | luxcore::Film | |
| OUTPUT_RGB_IMAGEPIPELINE enum value | luxcore::Film | |
| OUTPUT_RGBA enum value | luxcore::Film | |
| OUTPUT_RGBA_IMAGEPIPELINE enum value | luxcore::Film | |
| OUTPUT_SAMPLECOUNT enum value | luxcore::Film | |
| OUTPUT_SHADING_NORMAL enum value | luxcore::Film | |
| OUTPUT_UV enum value | luxcore::Film | |
| Parse(const luxrays::Properties &props)=0 | luxcore::Film | pure virtual |
| SaveFilm(const std::string &fileName) const =0 | luxcore::Film | pure virtual |
| SaveOutput(const std::string &fileName, const FilmOutputType type, const luxrays::Properties &props) const =0 | luxcore::Film | pure virtual |
| SaveOutputs() const =0 | luxcore::Film | pure virtual |
| ~Film() | luxcore::Film | virtual |
