MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
list=allusers (au)
(main | query | allusers)
Enumerate all registered users.
Specific parameters:
Other general parameters are available.
aufrom
The username to start enumerating from.
auto
The username to stop enumerating at.
auprefix
Search for all users that begin with this value.
audir
Direction to sort in.
One of the following values: ascending, descending
Default: ascending
augroup
Only include users in the given groups. Does not include implicit or auto-promoted groups like *, user, or autoconfirmed.
Values (separate with | or alternative): bot, bureaucrat, interface-admin, suppress, sysop
auexcludegroup
Exclude users in the given groups.
aurights
Only include users with the given rights. Does not include rights granted by implicit or auto-promoted groups like *, user, or autoconfirmed.
Values (separate with | or alternative): apihighlimits, applychangetags, autoconfirmed, autocreateaccount, autopatrol, bigdelete, block, blockemail, bot, browsearchive, changeemail, changetags, confirmemail, createaccount, createpage, createtalk, delete, delete-redirect, deletechangetags, deletedhistory, deletedtext, deletelogentry, deleterevision, edit, editcontentmodel, editinterface, editmyoptions, editmyprivateinfo, editmyusercss, editmyuserjs, editmyuserjson, editmyuserjsredirect, editmywatchlist, editprotected, editsemiprotected, editsitecss, editsitejs, editsitejson, editusercss, edituserjs, edituserjson, hideuser, import, importupload, ipblock-exempt, linkpurge, logentryimport, mailpassword, managechangetags, markbotedits, mergehistory, minoredit, move, move-categorypages, move-rootuserpages, move-subpages, movefile, nominornewtalk, noratelimit, nuke, override-export-depth, pagelang, patrol, patrolmarks, protect, purge, read, renameuser, renderfile, renderfile-nonstandard, reupload, reupload-own, reupload-shared, rollback, sendemail, siteadmin, stashbasehtml, stashedit, suppressionlog, suppressredirect, suppressrevision, unblockself, undelete, unwatchedpages, upload, upload_by_url, usermerge, userrights, userrights-interwiki, viewmyprivateinfo, viewmywatchlist, viewsuppressed
Maximum number of values is 50 (500 for clients that are allowed higher limits).
auprop
Which pieces of information to include:
blockinfo
Adds the information about a current block on the user.
groups
Lists groups that the user is in. This uses more server resources and may return fewer results than the limit.
implicitgroups
Lists all the groups the user is automatically in.
rights
Lists rights that the user has.
editcount
Adds the edit count of the user.
registration
Adds the timestamp of when the user registered if available (may be blank).
centralids
Adds the central IDs and attachment status for the user.
Values (separate with | or alternative): blockinfo, centralids, editcount, groups, implicitgroups, registration, rights
aulimit
How many total usernames to return.
Type: integer or max
The value must be between 1 and 500.
Default: 10
auwitheditsonly
Only list users who have made edits.
Type: boolean (details)
auactiveusers
Only list users active in the last 30 days.
auattachedwiki
With auprop=centralids, also indicate whether the user is attached with the wiki identified by this ID.
auexcludenamed
Exclude users of named accounts.
auexcludetemp
Exclude users of temporary accounts.
